all,
i am trying to create a PDF file from printing where a certain level is a color (red) and all other levels print black (for a "asbuilt" project) i have a existing plot table to specify this & for whatever reason it is not working now :( would someone care to share maybe what they do to create a plotted PDF file where everything prints b/w except a particular level???
thanks!!
c-j
p.s. i know this might be a little vague.. i am fairly new to microstation & not sure how to "describe" my situation & desired result LOL!
Unknown said:thanks for the reply... is what you are saying also possible by level filters???
Not sure what you mean by this. We have level libraries that we reference to level manager. That way the levels can not be deleted or permanently changed in our working files. This allows us to modify color, weight, linestyle (bylevel or overrides). Then if we want the levels set back to original we can just update the levels in LM. A lot of times I want to print everything black except certain elements I may have questions about so I just set all colors to 0 in LM except those elements make my print (whether pdf or directly to the printer) and then update my levels to reset the file. You can not do this sort of "custom" on the fly set up with pen tables in that short of a time span.
Mike
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
mike,
you actually anwered the statement i made by your answer. what you explained is what i was trying to say/describe. next time i do a check plot i will try the directions you just provided & see how that works-timewise.
thank you.... you have helped!
This works. On Step 8 I had to change the level color to 255,0,0. Also, make sure your lines, text, and cells are Color by Level and turn off Color Overrides.
It's 2023. This is still the best solution.
Once setup, I wish we could all agree turning ON/OFF the View Attributes > Level Overrides is the best approach to print that layer level with or without colors.Eugenio Palomo | Geospatial Task LeadGeospatial Task Lead8095 NW 12th St, Suite 301Miami, FL 33126Cell: (786) 337-3753Office: (786) 472-8172 x3009www.ctseinc.comepalomo@ctseinc.com
