I found this great keyin to round off dimensions
mdl load calculat; calculator mdlDimStyle_setDoubleProp(mdlDimStyle_getActive(), 0.005, 1083)
it works well.
Does anyone know if there is a similar type of keyin to round the angle dimensions to the nearest minute?
Regards Adrian
The Angle Format in the Dimension Style can be set to DD^MM' this is for new dimensions, or updating dimensions that are not dropped. Otherwise, for dropped text in an angle format a text find and replace should work. Find = [0-9][0-9]"$ and replace with a blank space, make sure to toggle on Regulare Expressions.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
