Team,
When I debug=5 MS 2004 or V8i I get an 'kind of' error that the definition of 'MS' from the msconfig.cfg
The debug shows that 'MS' was not defined and I have not found where in config to resolve it.
This happens in vanilla installs before any custom config is applied.
Has the MS variable in the msconfig.cfg been made redundant ?
Can you post msdebug.txt file you receive if you use -debug=5?
With regards,
Jan
Thex1138 said:The debug shows that 'MS' was not defined and I have not found where in config to resolve it.
The comments in msconfig.cfg …
#---------------------------------------------------------------------- # # If MS is set using a system environment variable, and MSDIR is not # previously defined, then use the value of MS to set MSDIR. # #----------------------------------------------------------------------
In a default MicroStation configuration, MS is not expected to be set. What the logic says in human terms is this …
Environment variable MS is used in an MDL development setup. That is, you would define MS as a Windows variable if you were an MDL developer. What I don't know is where & how _ROOTDIR is defined.
