I am sure I am missing a very basic thing here, but I have difficulty in moving my dimensions after they are placed. Say for instance the two dimensions are very close to one another and I want to move ones text up a bit to be visible again, what would be the procedure?
Hello Anneke,
Just active the modify element command, identify the text you want to move and it will 'slide' along the dimension line.
If you identify the dimension line itself, you can move that up/down or left right.
if you identify the extension line, you can move that.
Hope this is of help.
Best regards,
Henk
Great! Thanks so much
