How I can label a bearing and distance of property lines in MS8i?
Thank you,
use the key-in Label Line. In the active dimension style go to the Units tab and switch angle readout to DD.MM.SS. It will not show the N, S, E, W.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Thank you, I will try it.
You can make it display bearings easily enough.
Element > Dimension Styles. Go to the units tab and in the lower right under "Angle Format" change the display mode to DD MM SS.
Then...
Settings > Design File. Select 'Angle Format' from the list on the left. Change the 'format' pull down to DD MM SS and then change the 'Direction Mode' pull down to bearing.
Do a save settings and you should be able to label a line and have it show bearings and distances.
Terry Judy Jr.
MS SS2 08.11.09.357
GeoPAK SS2 08-11.07.536
Cook Coggin Engineers, Inc. - Tupelo, MS
Thanks for that tip Terry! I forgot about the Angle Format option.
No problem.
