  • what about datafields?
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • I wanted the keyin command to turn on Datafields in V8i, but I was going to post a second question on the same subject, different question. When making a text edit of a datafield you would see <<  >> and if you messed up on wanted to make text into a datafield 2004 V8 you could just put << in front and >> in back and it became a datafield, I tried this in V8i and the text came out showing the << >>, Is there a new way to make the datafields on the fly like the older version?  I hope this question makes sense and it is in the correct place?
    RJB Phillips III - Praise the Lord for His Mercy and Grace
  • Try using the dialog box text editor in MicroStation V8i. You can change the text editor by going to Workspace>Preferences pull-down menu. Go to the "Text" category and select Dialog Box as your text editor style. You can then enclose your text inside the brackets to make the text enter data fields.
Reply Children
