I am using text masking just fine. But after I changed the note to another level (I didn't change the text style), the background became the color of the level, and the text couldn't be read anymore. I already tried to match properties.
Does anybody know how to solve this problem?
Wilfred
you probably have an symbology override applied the new level... in view attributes turn off overrides to see if you get any changes.. if so then a level override is the culprit.
Lorys
Thank you for your reply.
I turned off the Level Overrides, but it doesn't change anything to the appearance of the Note.
Hi Wiflred,
It's time to bring up a small dgn example (save fence as dgn!)
Frank
in the textstyle: Is the background fill color -1 (byLevel)? This is - what I think - the only thing that would change the color of the background when changing levels. What color do you want there? If you want it to be the background color change it to B (BG) - or to any other color you like. Check the bylevel-color of that new level (level symbology in level manager) and of the previous level. HTH, Gerd
Hi Gerd,
My problem is solved checking you tips. I selected all text with the selector by Text style. Then I used Change Text Attributes and I clicked Text Style. Suddenly I could see the text, using text masking. So my issue is solved. Thanx!
