I am looking for a feasable solution for a standard problem. Several elemets alining on one line need to be dimensioned. There are hunderets of that elements and i know that other CAD-programs have smart dimension in which you draw one line and any intersetion would create on dimension. Is there any similar tool in microstation? any MDL app or macro or add-on?
Help is apreciated, many thanks.
best, nico
Microstation V8i select series 2
If you are doing Linear Dimensioning the tool settings box has a toggle for that abilty called "Select Multiple Elements", the toggle is on the lower left side of the settings box (looks like 2 little blue circles with a line between them).
Don't know if there is a way to do that with any dimensions other than Linear.
Thanks alot! Almost embarrising I couldn't find it.
regards, nico
