Older MicroStation versions on Windows 7
We are about to move to 64 bit Windows 7.  I have been maintaining older MicroStation versions because it seems that no matter what new version comes out, there is always some bug that wasn't in a previous version.  Many of those problems can be worked around simply by using one of the older versions.  Sometimes a file that won't open in a recent version will open in an older version and can be repaired or extracted to a clean file using the older version.  As an example, I've run into instances where using the Modify Element command on a specific vertex in a very simple line string or shape (say half a dozen points more or less) will cause V8i versions and XM to crash but is handled by 2004 edition with no problem at all.
The bottom line is that I want to keep the older versions around, installed, and usable as long as possible.  So, has anyone had any luck installing these MicroStation versions on Windows 7 32 bit and 64 bit - (I ask about both Windows 7 versions in the event that we can convince our IT to provide us with dual boot machines instead of just the 64 bit OS):
MS/J
V8 2004 Edition
XM
If you have had success, but had to use some special installation procedure to make any of the above work, please post the procedure(s) so they can be forwarded to our IT.
(I understand that the best solution to any problem is to report the problems and provide sample data so they can be fixed or find a work around in the current version but, in the real world, project schedules and budgets often won't accommodate waiting for a bug fix, or a drawn out trial and error trying to find a work around if temporarily using an older version expedites the work.)
Parents Reply Children
