Force a line break?
Alright, guys, what I'm trying to do is use model properties to set up fields to populate my title block. What I've run into is that sometimes I need two lines for my drawing title. Does anyone know of way to force a line break in the model properties dialog as opposed to using two different fields? Our office's font of choice is Lucinda Sans Unicode... I went through the character map looking for something that might do this but didn't see anything.
As a side note... It would be handy if we could have "custom" lines. For example we have Name, Description, Ref Logical, etc.. would it even be possible to add some blank ones to the bottom and label them like Custom 1, Custom 2, so on and so forth?
  • If you're willing to always have a blank line, fields should honor word-wrapping. In other words, when you create the title block with the title field, drag the corner elements handles to define a wrap distance; when it's populated later, it should then become two lines as necessary. Of course, you then need to space it out to have two lines all the time, just in case one of them does.
