In a previous posting, Jeff Marker alluded to a "V8i-compatible font utility app" and suggested contacting "our support group for more information." Where can I find/get that application?
Currently, the way to do that is to log a Service Ticket.
Hi Phil,
Does this means that there is an utility available by filing an ST or that the service desk will do the .rsc maintenance for us?
Marc
Unknown said: Does this means that there is an utility available by filing an ST...
That is a leading question :)
Seriously, submitting a Service Ticket on the subject will result in various information returned, depending primarily on the specific release of MicroStation you are using (note that we do not provide a service to do font resource maintenance).
Downlaoding, installing then using V8.5 on a 15min try out was sufficient for me to do the task at hand, extracting a font needed by some old files, sledgehammer to crack a nut though.
Given that this problem comes up over and over again, why can't Bentley just release it as an iWare app or an MDL app? I have a DOT-supplied font .rsc that I would like to get in and customize to meet our internal standards. Is the only way to get this via an ST??
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
