I made some Auto fields in my dgn that Should update automatically with the "File Name" property.
I'v checked v in "Update Fields Automatically" and nothing append the fields dosent update.
I need to update them Manualy.
How i can solve it ?
Why not post a small example DGN that illustrates your problem?
I attached a dgn file.
There is a field that called "file name" - this field need to update automatically.
try to change the file name, and u will see that nothing is Happens.
Thanks.
Unknown said:Why not post a small example DGN that illustrates your problem?
Unknown said:I attached a dgn file
Your DGN file is 800kb. It contains a lot of graphics. Neither I nor anyone else wants to look at every text element in your model to find the one that has a field that references the file name.
Sorry about that.
I attached the worng file.
Now I attached smaller one.
Maybe it's because the text is in a cell?
I've attached a ZIP file with two versions of your DGN file. I've given them suffixes _A and _B. I place a text element in each and assigned the file name to a text field. The text shows the file name correctly in each case.
