Is there a way to place a field as a key-in? For example, if I use the place text tool, and right click in the text editor, I can chose "Insert Field" and then choose a field to insert like File Properties to insert the file name. Is there a way to do this with a key-in?
Something like ...
place text; <field properties>; xy=0,0
