Dimension Lines - Controlling Length with Small-Width Dimensions
I'm having some difficulty locating the ability to define the length of the "extension" coming out of a dimension line (see below) when placing a small-width dimension. I am unable to find the correct setting in the Dimension Styles to alter this, and I would like to control it in my .dgnlib so that my users are consistent with the dimensioning. I would like to avoid having to drop each dimension in order to lengthen that pesky little line. Any help is GREATLY appreciated. Thanks!
  • Under the Geometry Tab go to the Fit Options check on Min Leader and give it a value.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • As mike shows
    The Min. Leader has a two fold purpose: It sets the minimum distance it uses to determine if the text (and/or terminators) are inside or outside (fit between) the witness lines (depending on the Text /Terminator option chosen), and it also uses the length (in Text Width Units) for the line for that extension.
    I Hope this Helps!
  • Worked like a charm! I found that setting this value to 2 or greater gave a nice, proportional length.
    It would be very helpful if Bentley provided a few sample dimensions in their Help documentation that were labeled as to what each width/height/length/etc. meant!
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
