Dimension Lines
Is there a way/setting to force the dimension line to not be drawn between extension lines?  It appears that the text and terminators can be forced either in our out of the extension lines but it doesn't appear that there is a way to eliminate the dimension line between the extension lines.  Unless I have overlooked a setting somewhere.  I appreciate any help.  TIA.
V8i SS2 V08.11.07.443
