I haven't had to think about dialog box colors for years. Now we have Windows 7 and my dialog boxes have become somewhat unreadable. See the two examples in the attachment. One is from Workspace Config. I clicked on Primary Search Paths and chose Design File. When you select an item it blanks out. It still functions and displays the correct paths, etc, but is very annoying.
The other example is from Level Manager. Reference files that are attached but turned off are an unreadable green color. Way back we used to be able to change these colors using the Tool Colors Dialog Box. I can't find this box under Look & Feel. Is it gone for good? Are these colors ruled by Windows 7's Personalization? Am I just forgetting how to do it?
MS V8i (SS2) 08.11.07.443
That looks like you selected a Win7 Personalization that does this. Start with the default setting and you should be fine. Regards, Gerd
