Microstation V8i Missing Fonts
I am missing font #8 - Helvetica_Medium. It seems that i am missing a good number of other fonts as well. Please help with this prob. Thanks
  • I've seen this problem with legacy font .rsc files that were used in MicroStation J and brought forward to MicroStation V8.xx. In MicroStation J the only way to get access to TrueType and PostScript fonts in MicroStation was to import them into your font .rsc file. As a result, many users imported these fonts into their font .rsc files.
    When using .rsc files in any of the MicroStation V8.xx releases that contain imported true type fonts, the true type font definitions in the .rsc file override the matching windows true type font installation. I have found that this conflict can make either version of the font unavailable in MicroStation, or that the font is displayed out of order at the end of font  selection drop-down lists.
    The fix for this is to remove the True Type font definitions from all of your MicroStation font .rsc files. I seem to remember a post about a .rsc font editor being available for MicroStation V8i SS3 but cannot find it. Otherwise you can install a copy of MicroStation J and use the Utilities > Install Fonts tool to edit the font .rsc file.
    Rod Wing
    Senior Systems Analyst
  • Thank you all. I appreciate the advice. I am using Microstation V8i. I was able to solve the problem.
    I had an rsc file that had the font i needed, but was clueless on how to install it.
    The steps to install RSC riles.
    Workspace > Configuration > Symbology
    Click Symbology Resources and press Select
    A window should pop up so you can select the RSC file and click done.
    You will have to restart microstation in order to use the newly loaded fonts.
  • I've been using TTF since we moved to V8. Before that, we used Bentley delivered RSC fonts. We didn't import any TTF to RSC. Everything has worked fine from V8 to 8.5 to XM to 8i SS2. It's only in 8i SS3 that I can't "find" Tahoma, Verdana and a handful of other TTF.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • In terms of font hiding, have you seen: communities.bentley.com/.../fonts-in-microstation.aspx
    Did you modify the font configuration in SS2 to prevent the hiding?
  • No. I guess we've been in blissful ignorance. We don't even have a font XML file (I looked). I wouldn't even know how to write an XML file. Isn't one delivered?
    MaryB
