I understand that the Number of microstation fonts are 0-255.
There is way to edit the microstation fonts library ?
deleting and adding to this library ?
Thanks.
Although it is true that you have access to up to 256 MicroStation resource fonts, that is generally considered the "old way" of doing things with text. In the "V8 generation", MicroStation supports three types of fonts: True Type, RSC (i.e. MicroStation Resource Font), and SHX (i.e. AutoCAD Fonts), so there are a great number of better ways to handle text. Is there anything specifically you want to achieve by "deleting and adding to this [MicroStation font resource] library"?
I want to add my fonts to bentley's fonts and using the font number in the "Change Text Attributes"
When i'm change to my font I cant use the font number:
Unknown said:When I change to my font I can't use the font number
How did you create your font library?
We do not provide utilities that allow for Fonts to be converted from one type to another type. For the best fidelity it is recommend that you use fonts in their native format. It appears to me from your images that you have SHX fonts. Why do you feel a need to change these to RSC based fonts?
Jon:
MS_DWGFONTPATH=w:\fonts\
and I'm adding fonts to the fonts libary.
John:
I want to use the font number option with shx fonts.
There is a way ?
