Autocad name in Microstation
I have not used anything but Microstation for a few years, but today I need to use the Leader (aclt command) tried the help F1, but did not get an option on Leader, would someone tell me the Microstation tool bar or command for placing a Leader.
  • Under the place text command tool bar. Use the Place Note command. To place a leader just start the command and don't enter text into the text editor. You will need to set some preferences. Just click the little magnifying glass in the tool settings dialog. I think there may be some other tools in another Task area but I use this method.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • This was a big help, thank you so much for the assistance. RJB Phillips III
    RJB Phillips III - Praise the Lord for His Mercy and Grace
  • BTW If you know the acad command and cant think of what the ustn command is  then from the keyin window type dwg  then you'll see all the available acad  commands available make sure you use the browse key in as shown and if you select one it will launch the right ustn  command so get to recognise the icons instead of acad commands...
    Lorys
    click link to PM me
  • As an Autocad user who has struggled with not knowing equivalent Microstation commands, this is a great tip.
    Neil Wilson (aka Neilw)
    Power Civil v8i 08.11.07.245
    AutoCAD Civil 3D 2018
  • FWIW, there is some real good information regarding that in Help > Contents
    Once you navigate to that (or get to it through the Search function), click on the "Show All" button in the upper right hand corner to expand the entire topic at once.
Reply Children
