how i can get mdl application changetext, textutilities etc
Unknown said:changetext, textutilities
It's not clear what you are requesting. MicroStation includes many MDL apps. that implement a command. They are delivered in the \MicroStation\mdlsys folder and its sub-folders.
I don't think that changetext or textutilities are part of the standard delivery. Where have you read about them and what do they do that isn't provided by MicroStation?
you can get some useful things here
http://communities.bentley.com/communities/other_communities/bentley_library/default.aspx
celltool
civtool
area tool
other stuff can be found in ask inga has your text rotate via angle assistant
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/active-angle-assistant-macro.aspx
or google but when you google its hard to find the current versions that work with your platform..
another great source of tools is envision cad's free tools and cadguru's and a lot of of the usa DOT ( dept of transport) most of which use microstation have contractor downloads and free tools....
otherwise tell use what the tool you want does and we other users may have a macro that does what you want the trouble with mdls is they are platform specified but most vba and msbasic will mostly work if you havent used level numbers for several platforms.. I have macros from v8 2004 that still work...
Lorys
