Is there any way, in plain vanilla MicroStation, to measure the slope of a line? Assuming 2D, basic XY coordinates, no exaggeration.
Thank you
MaryBMSTN 08.11.09.397
MaryB
1. Draw a Line
a. snap to one end of your line
b. with accudraw active drag this new line to the right and type 100 in the X value in Accudraw
c. drag the line up and in Accudraw type N (nearest)
d. snap to your existing line
n
e. Accudraw will display the Y value with being a factor of the X 100 is a percent
2. so reading the value in Y the slope of this line is 20%
3. you can copy a value in Accudraw for pasting in other places (placing text)
4. you can Reset to cancel placing the second line, once you are satisfied with the results.
Try it a few times with different lines to see if it is what you expect.
NOTE if you are working on an exaggerated scale (10:1) use 10 in stead of 100 for the same results.
ALSO: if you want a line at a set slope, you can begin drawing the line and type 100 for X and "your slope" for Y, then type A to switch Accudraw to Polar input, and you will be able to extend the line to the correct Distance.
Brent
Accudraw ... Learn it, Live it, Love it.
pretty neat solution, I like it!
Lorys
Thanks. I know how to create and calculate a slope. I guess I was hoping the there was some sort of dimension or measure tool that could do it for me.
found this bas file from Noah Gordon in the ng archives you gotta love google for this kind of search the forum search missed it completley..
works in V8i great and also 3d just measure no labelling.. just what you asked for ... sent you copy off line no thought it best to share it with everyone so it comes out of the archives for a while and hopefully some one can modify it in vba to have some other options beside percent and some gui menu...
Slope cannot be calculated in a 2d file. Slope is relationship of the change in elevation to the horizontal distance. There is no elevation in a 2d file. The provided basic macro requires a 3d file.
