Is there any way, in plain vanilla MicroStation, to measure the slope of a line? Assuming 2D, basic XY coordinates, no exaggeration.
Thank you
MaryBMSTN 08.11.09.397
Not true. Macro reports a 2D slope based upon Delta Y/ Delta X but 3D slope based upon Delta length/Delta Z.
This version adds a place text above line in the middle - only uses 2D slope in this version.
This is a detailing forum, have you ever seen cross sections done in 2d on a 2d sheet not every one has access to inroads...
Lorys
Caddcop.. did you modify the one I posted as now it labels where as mary just wanted measure... nice one
Now can you edit it to make it ask user keyin 1 or 2 for % or 1( rise) in X( run) ratio ( .. I tried but it wrecked it!)
but this does look a lot like the original haven tried it but will it still measure 3d slope after your mods...
You may want to try using the Display Style: Slope. The tool tip should display the slope.
My post is simply a slightly modified version of the original. It still echo's 2D (and 3D) slopes, but only uses the 2D slope as a label.
I had one a while ago that did that. I will see if I can locate it.
What you need in these, is a check against a rotated view as this version will give wrong result as written. There are alternatives to get the slope in any view orientation, but I have always struggled with that type of code.
What I imagine in a finished macro, is a dialog box that opens after accepting the line and in the dialog box is the slopes with radio buttons so you can select 2D or 3D slope as a label and options for % slope, rise over run, run over rise and different labeling options - above, below, by origin or in a leadered note.
