Is there any way, in plain vanilla MicroStation, to measure the slope of a line? Assuming 2D, basic XY coordinates, no exaggeration.
Thank you
MaryBMSTN 08.11.09.397
Dom that must be in SS3 I dont have that in SS2 or ss1
Lorys
CAD COP I have that one I think it was by Tim shoemaker of the TMC but it is compiled version of bas and needs 2 macros but it only works in XM not 8i.. slopeset.ba and Slope.ba
the Slopeset.ba works in 8i but not the label slope which is slope.ba,
Here is a vba I wrote many years ago, it does ratio/percent as allows for exag, and adding a negative in front of the number. The keyin is "vba run [slopelabler]startup.main". it does not factor the z in a line.
Larry WilsonLWilson@LJBinc.com
find a horizontal line or draw a 2d line that is horizontal starting at one en of your item
Then use hte measure tool to measue the angle
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Unknown said: Here is a vba I wrote many years ago, it does ratio/percent as allows for exag, and adding a negative in front of the number. The keyin is "vba run [slopelabler]startup.main". it does not factor the z in a line.
thanks a big bunch Lawrence
from Lorys
