MicroStation SS3 - Not all but some of our Workstations and Laptop that are running MS SS3 are crashing to the dialog "MicroStation stopped working" when we try to load anything to do with a VBA. Even if we try to go to Utilities > Macros > Project Manager MS SS3 will crash. We are wondering if there is any information on this and what the fix would be. Windows 7 (64 bit), MicroStation (SS3) - 08.11.09.357. We have also notice that MCM is being unloaded after startup, not sure if that is related. Any help would be appreciated.
Does the crash create an Exception Log?
Can you load the VBA in the default delivered workspace?
How much dedicated memory does your video card have and what is the driver date (can both be found by running dxdiag.exe)
Can you narrow anything down about the machines that are having issues? Specific users/ files/ times of day?
Are the DGN files on the local machine or the network? Does the issue occur of they are local?
Thanks!
Thank you,
Dan Koval
BSW Solutions Manager
Having the same problem.
uStn SS3
InRoads SS2
Win7 64
16GB RAM
1.7GB Video Memory
NVidia Quadro 3000M
Files are local
Unknown said: Having the same problem.
Is it the exact same issue?
Can you answer any of the questions previously posted?
We are not finding any things that seem different with these workstations, like right now I have one in an office but all the other in the office that are exactly the same work, where this SS3 install will fail when trying to open a VBA. I am not sure where to even look to figure this out. Yes, even if I use the out of the box configuration, I still get the failure of MicroStation.
here is an exception.log file when loading a vba crashed MS SS3.
