Is it possible to run a keyin at startup? I saw this AskInga article from 2002 that says one can create a txt file and then point the icon properties to it but I imagine that's pretty out of date by now?
You could also use the autorun.mvba file to run keyins via vb. I use this a lot, very handy.
It is also possible to use MS BASIC macro as autostart.
MS_DGNAPPS > RUNMACRO
MS_DGNMACROS = autostart.bas
2.Then create autostart.bas under Project\macros
3. Edit Autostart.bas and add key ins with command MbeSendKeyin followed by key-in enclosed in qoutes
MbeSendKeyin "set nodes off"
Now each time a file is opened the macro will run. Keep in mind that this soon will be outdated also because in newer versions MS BASIC support could be dropped.
Unknown said: I imagine that's pretty out of date by now?
No, the contents of the noted article are still valid.
Other articles of interest:
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/run-a-vba-macro-when-opening-or-closing-design-files.aspx
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/run-commands-or-basic-macro-when-opening-files.aspx
What format would work in V8i Select series 10 nowadays? I'm looking to do exactly that.
The link below to a VBA macro is absolutely viable (I do this).I imagine that for V8i, the link to running commands would still work as well.
MaryB
