MicroStation V8 2004 editon's text editor doesn't work while Logitech software SetPoint is running (it is my Logitech M500 mouse settings softaware). When i'm trying edit text MicroStation become "Not responding", but if SetPoint is turned off (I exit from that soft) text editor works perfectly again.
Is it any solution that both softwares (Microtation ang Logitech SetPoint) work simultaneously without problems?
P.S. Windows 7 Pro 64-bit
2004 Edition is not certified to run under Windows 7 (if my memory serves correct) Just out of curiosity: If you upgrade your OS why not the Software?
Same problem here...... thank you for your finding.
As stated by Gerd, MicroStation V8 2004 Edition has not been certified for use on Windows 7. It should still work ok, though, but may need a some small modifications. Looking through some previously raised discussions in the Communities with the Setpoint software it seems that your issue may possibly be related to the version you have installed. It may be worth looking at the version you currently have installed and to see on the Logitech website whether they have a more recent release of this.
