I'm trying to create a txt file to use with batch processor that will merge a reference and then detach the rest of the references. The commands to do this work fine except there is a prompt to click OK after both commands. Is there a command that can be used with batch processor that will dismiss or surpress the Alert dialog? Any help would be appreciated.
try and record a vba macro first do the the merge ( file name)
then keyin reference detach all and select the ok button ..( I just tried tried it and does record all steps including the accept)
you can then run this macro in your batch process..via the script command vba run ( vba project name) module name < FYI you have to name these.
I have run macros inside batch processor before and they work fine ...
Lorys
Unknown said:try and record a VBA macro
Five gold stars!
Recording a VBA macro.
mine works perfect for me dont, I have to click dont show anymore, I only clicked ok once and it got recorded as VBA macro, try running inside batch processor...
did not add the merge ref as you'll need to edit the VBA macro your self
attached my vba macro here for you to try...
you need to just have one line in the batch processor file
VBA run { vbaproject name} macroname.subroutinename
and in the batch process you defined which files to process,
and it just reruns the vbamacro over and over on each file it opens no need to ok or never click choose never show again ( I hate doing that as it has impact)
detachAll.mvba
