This problem has resurfaced on a Win7-64bit pc with an Nvidia Quadro 4000 video card, using Nvidia driver v320.00, running MicroStation ss3 v8.11.9.357. Specifically, the display may freeze, then black-out, then recover with an error message, as previously reported. For us, this error was repeatable, and occured when zooming in and out while in the middle of the place dimension command.
The workaround reported in http://communities.bentley.com/products/microstation/w/microstation__wiki/4172.aspx does seem to cure the blackout problem.
This problem was previously reported, and was supposedly fixed with Nvidia driver version 307.32 and/or 307.45, depending on the version of video card, according to bentley.
I will download and install that version of driver to see if it cures the problem as previously reported.
I can confirm these Problems with Nvidia Quadro Driver 320.0, even without using Microstation, Win 7 64 with other products only.
Our firm has been patiently waiting for some time now after being told from Bentley that their developers were "working with nVidia" to resolve the DirectX11 problem. I understand that a temporary workaround solution is to revert our workstations back to DirectX9 but we view that as only a temporary workaround and any suggestion that we should view this as a long-term solution is a somewhat inferior response to the issue; we do not view this as a viable long-term solution and my understanding from prior conversations w/Bentley personnel has been that Bentley does not either.
We're running Quadro4000 cards on Dell Precision workstations w/ Win7-64bit. We did notice a reduction in the occurances of the familiar usually momentary black screen w/ auto-recovery but occasionally fatal lock-up video driver error when the v311.50 nVidia driver came out but the errors were still occuring. And we confirmed that at the next driver (v320.? as I recall) the problem still existed. We just downloaded the latest performance driver for this card (v331.65) and still I see no listing for any Bentley app in the global presets pulldown options distributed with the driver. And still If one navigates to the certified drivers portal on the nVidia site and drills down to the Bentley certified drivers page we see that the latest BentleyMicrostationV8i certified driver for Win7-64bit = quadro-win7-winvista-64bit-258.96-whql with a release date of 2010-07-19. This finding is not yet supporting statements from Bentley that they are "working with nVidia to resolve this problem". Mr.Smith: Can you or someone else w/ Bentley please let us know if indeed this problem is being worked on at all and if so what your target date is for a resolution? Thank you.
We're running AECOsimBDv8i-SS3 (v08.11.09.376). I am not aware of us having encountered these video error problems with any of the other applications which we run and several of those programs are similarly 3D graphical in nature.
We use the Dell systems also and are very disatisfied. They are like a model T and last, but they are the low end of tech. The video is a good example - it is very low end for the price. (at least what the govt pays for their machines)
There are very cheap cards and better cards that can be added to replace those. This is not a suggestion to buy as I know this is a pain, but another workaround.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
