This is a problem I had before some many months ago, but I have a rebuilt PC and the issue has returned and I forget how we resolved it.
Even on very lightweight files all functionality is perfectly fine but anytime undo is triggered either from menu, ctrl-z or toolbar icon my machine will freeze for 5-10 seconds. It makes no difference what the 'size' of the action being undone is, always a delay.
As I said, we sorted this before on Ss2, but a new machine and Ss3 the issue has returned.
Is there a size of undo buffer somewhere that will be causing this? It's baffling as it affects enormous models or simple near empty files.
Please, this kind of question needs a lot more info for us to follow your installation.
The easiest way is to share a MSDEBUG.TXT created with Microstation command line argument "-debug:4"
Frank
Please provide the version # and the undo operation (e.g. undo place line). It's important b/c I just tested a few undo workflows in Update 2 -08.11.09.459- and found no delay.
Chris
