I can’t reference Rhino files when there is a material witha bitmap attached in the Rhino file. It either hangs or crashes.
I had this problem in 08.11.09.357. I recently installed 08.11.09.459as it has Rhino 5 support. The problem is still happening.
Are others having this issue?
There is an obvious workaround of detaching the material inRhino but it should be fixed.
Richard
Richard,
If you haven't already contacted technical support and provided a test case, would you reply here and include one?
Chris
Attached is a zip file with 2 rhino files embedded, one with a material attached and the same one without.
Thank you for providing the files. I am looking at them now.
Dan Koval
Thank you,
BSW Solutions Manager
Hello Richard,
It appears that there is an issue with the software, this has been logged as a Trouble Report, TFS#19434
Answer Verified By: Joshua Kulp
thanks Dan.
