Hello,I am a little confused about how the levels are displayed in the level manager and level display windows.
Normally, it is so that use levels are highlighted in bold!
But now I see that even unused levels are in bold?
Now I have found out that the corresponding level is not used in the actual MODEL, but in other MODELS of this drawing.In the Level Manager I opened the properties window of the affected level and could see in the last tab "Usage" that the other models are listed there as used.
In my opinion, if I am on a specific Model where I open the level display window, it is not right that the display refers to all models of the DGN !!
At the moment I work on a specific model and I think that, checking whether used or not, should be limited on this model.Or am I wrong?
Raphael
Hi Chris,
In MS, it´s not possible to use a separate level table for each model of a DGN, so all existing and required levels must be in one single level table.
IMO that’s a reason why model based a better overview of the used levels will be important.
A case where I would want a better overview .....
For example, when splitting an existing drawing on several models, I would like this.
For example, if from a common level table you want only using individual levels on specific models, that means divide the levels into groups and assign them to the models, it would be helpful.
As it appears at the moment, I´m always again confused when check whether a level is used on another model as the active one, which would mean that there still are elements on it.
Of course I can also examine each specific model for elements, but a good and quick overview could be done through the level display window.
As described in the last post, it´s not possible to identify whether a level is ONLY used in the current model.
An example scenario:
I work on “model 3” and only on this model elements on “level 10” are allowed. In the level display window the “dot” indicates that this level is used on the current model (OK) in addition the text is “bold” because this level is used in this file.
But it´s not recognizable if “level 10” is used ONLY in the current model.
Or am I wrong?
Hope I could explain it without further confuse :)
There is a way to obtain this information; check the Usage tab of the Level Properties dialog. Alternatively, use the level usage keyin (Command format is : level usage [file:file-spec] level-spec).
Given that the level could be used in tens of models, the type of information you are looking for appears best communicated in a list; however that's not to say the current method we use to communicate usage in the Level Manager and Level Display can't be improved.
Chris
Chris,
Thanks for the tipp, but this is what I had written in the main post. By this way I found out that the other models are listed as used on a specific level.
I agree there are one ore more possibilities to see the needed Informations, but if I can have this on a window like the "Level Display" who always been opened.......
that will be smarter :)
"however that's not to say the current method we use to communicate usage in the Level Manager and Level Display can't be improved."
For improvements we are always grateful...
who knows.... :)
What a about a open circle rather than a filled bullet to indicate "Used in File" vs "Used in model"
Unknown said: however that's not to say the current method we use to communicate usage in the Level Manager and Level Display can't be improved. Thanks, Chris
Indeed it can:
(a) A capability (say a "mode"?) to display used Levels on a per Model basis could worth solid gold.
Why may you ask: Well...exploit this rather simple pedestal bridge where Models are used as Refs and/or as Shared Cells depending on some assembly/component way of thinking (although Microstation is not designed that way, far from it). You can easily see that "components" have their own mind about their Levels and displaying Level usage "per dgn basis" is utterly confusing and unproductive. Of course in this type of design attempting to use Level dgnlibs and the likes is like 3rd marriage.
(b) all drop down Level lists should operate on the same manner with regard Level usage.
(c) multi Leveled Shared Cells (as is the norm in component design) must be allowed to display ALL used Levels. As it is : well....you know...
(d) Some say that Levels, Level libs and Level driven 3d CAD is the future. I say that is the past. Why way you ask. Well...imagine (in a few years from now) a generative (or algorithmic/scripted) way to design 3d objects - on a per 3d object basis....
So with this (rather simplistic) bridge on hand .... the 1M question is: can you effectively handle what's going on?
Notify if you need some more complex cases.
best, Peter
