Configuration 'Colors'
I'm trying to understand what the configuration settings mean under the 'Colors' filter. The Default color table is pretty obvious but what are the others used for or by? I'm currently running V8i SS2, in case its different in other versions.
-Right Menu Color Table
-Left Menu Color Table
-Colorbook Library List
-System Color Books Directory
Thanks.
  • Unknown said:
    • Right Menu Color Table
    • Left Menu Color Table
    Relevant when you have multiple phyical screens.
    From MicroStation XM, so including your version, MicroStation has supported 'true' colours (i.e. 24-bit RGB values).  That's a 16-million colour palette.  Since most of us can't distinguish or describe sixteen million colours, Color Books provide a way to categorise a large number of named colours.
    Pantone Blue 294
    If the traditional Color Table floats your boat, then you can ignore Color Books.  If, on the other hand, you want to use that specific shade of Pantone blue 294, then you will find Color Books useful.
    Regards, Jon Summers
    LA Solutions
    Answer Verified By: slehner
