Linestyle in nested reference file appears as linestyle "0"
Post on behalf of Be Communities member:
MicroStation V8i Select Series 3 08.11.09.459
Linestyle(s) in nested reference file appears as linestyle "0". This occurs even though in the actual file the linestyle is defined as a custom linestyle. The currently is occurring in one attachment only and problem is seen only when the custome linestyle is assigned to a level(bylevel). The problem occurs in both the parent file and the master file that the parent file is attached are opened read-only.
  • Hi all,
    Just wanted to personally follow up on this issue since Regie posted this on my behalf..
    Based on the replies, I would like to recap the details I am having with this issue:
    - Problem only occurs when file is opened read-only.
    - Problem only occurs in reference file.  Appears to be just one file (that I know of).  Linestyles display correctly when subject file is opened directly.
    - Only affects elements that are assigned a linestyle (ByLevel).  Elements that are directly assigned a linestyle display correctly.
    - Level Manager displays linestyles as they appear in file (ByLevel view).  Some appear as "0", some appear as the linestyle that was assigned to some Levels.  Only certain levels are affected, not all.  None are displayed in "red".
    - Level libraries are not being used for this workspace.
    - Attaching the same problematic file again to the parent file appears to work (display) correctly.
    I will update this thread if I find a solution to this...
    - Ray
Reply
  • Hi all,
    - Ray
