Post on behalf of Be Communities member:
MicroStation V8i Select Series 3 08.11.09.459
Linestyle(s) in nested reference file appears as linestyle "0". This occurs even though in the actual file the linestyle is defined as a custom linestyle. The currently is occurring in one attachment only and problem is seen only when the custome linestyle is assigned to a level(bylevel). The problem occurs in both the parent file and the master file that the parent file is attached are opened read-only.
I think I resolved it...
I "Compressed" the problematic reference file and now it displays all linestyles correctly when being displayed Read-only.
- Ray
Answer Verified By: Reginald Wallace
