Convert Working Units - Metric to English
(Posted on behalf of Be Communities User)
How do I convert metric units to english units.
  • Go to Settings > Design File > Working Units > change the unit from meters to feet or vice versa. The units will convert to the equivalent unit.
    Tamicca Sellars
    Product Manager I
  • Also If you consistently go back and forth here are some keyin to put into a pull down menu or function key.
    set units Meters;vba execute ActiveSettings.CoordinateAccuracy=5;
    set units Millimeters;vba execute ActiveSettings.CoordinateAccuracy=1
    set units feet inches;vba execute ActiveSettings.CoordinateAccuracy=1;
    set units feet inches;vba execute ActiveSettings.CoordinateAccuracy = msdAccuracyHalf
    set units feet inches;vba execute ActiveSettings.CoordinateAccuracy = msdAccuracy16th
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
  • Eric Milberger, could you add a little assistance for me.
    the standard I have to work with  Set units inches inches works, but actually they are in Inches and Custom
    which is tenths
    I hope you can assist me on this or someone, I have tried VBA record several times, am not able to get to work
    I tried to load the mdl DGNSET and get the key-Ins but when you load it, the keyIn section is grayed out.
    Version: MicroStation V8i SS 10
    RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
    The original post, and 's response, were in 2013.  I haven't noticed any post by him in recent years.  Eight years on things may have changed.
    It's best if you start a new post.
    I have tried VBA
    You don't need VBA to set your DGN model coordinate system.
    When you post your new question:
    • State the version (e.g. v10.x.y.z) of MicroStation you are using
    • Add a DGN file (menu Insert|Insert image/video/file) with a single model
    • State what unit settings you want to achieve
    Regards, Jon Summers
    LA Solutions
  • Thank you for the great advise, I saw the partial answer worked Set inches inches, so assumed it would be easy for someone who seemed to know the key-In so well. I had looked and looked, even in a MicroStation reference manual.
    I will try to follow your information. not sure what the DGN file (Menu insert is ) I had added the pictures showing I was trying to open the CUSTOM section and then put in the numbers. So appreciate the input.
    I sure admire some of the amazing helps you post online, Mind blowing to me, but amazing and so thoughtful of you to help so man as Jan does also. I read a lot of questions and you two show up a lot.
