[V8i] Unable to move Georeferenced File after Changed to 'NO'
Posted on behalf of Be Communities member:
In MicroStation V8i SS3 08.11.09.397 and 08.11.09.459
If a reference file was attached with the Attachment Setting, Georeferenced - Reprojected, then the setting is changed to No, the reference file is not able to be moved.
Worthy of note, if the same process is done and the original attachment method is AEC Transform first, then changing to No, the reference is able to be moved.
