On several workstations the display of text in the MicroStation Word Processor is showing a 1/64 character in place of spaces (multiple spaces, one space seem fine). I have attached an example image, it seems to be only spaces at the start of a line witch is very strange and awkward. This seems to be an issue for several fonts but not the True Type Fonts. We typically use the MicroStation fonts because the support line weight and true type fonts do not. When the text is back in the MicroStation view it appears vine, the text editor dialog box mode seems to work fine. Are there any fixes for this?
There are a couple of options:
Be Communities Thread: Double spaces show as fractions in editor
Craig Calvin
Bentley Technical Support
