I was wondering there is a tool that will measure any linear element AND place a piece of text like ATOOL.MA does for areas.
Thank you
JDJATKHA said:I was wondering there is a tool that will measure any linear element AND place a piece of text
Here's a LowCostLabeller tool that answers that question. It's freeware. It's more capable than the VBA macro described above.
It demonstrates association (the label move when you move the line). It uses a text field to display the line length, and it updates when you edit the line.
Oto said:Could it honor segment orientation also?
You can orient the label along the line segment.
Brian V said:I suggest enhancing this tool even more by placing the text on whatever rotated view is on?
You can orient the label aligned with a view.
