Text Style Height and Width place based on a variable
I am trying to write some line styles that will need variable height, width and line spacing based on the horizontal scale of the drawing. Something like
Height = 0.1 * HorizScale
Width = 0.09 * HorizScale
Color = 8
Weight = 4
Font = "Arial"
Would the best method be to create the line style then wehn placing it change the height and width at that time?
MS version 08.11.09.459
  • http://translate.google.it/
    I do not know if it is the right method but it works in VBA
    first create the test style o"style_name"
            dim fsx as double  ' HorizScale
             CadInputQueue.SendCommand "TEXTSTYLE DESELECT ALL"
             CadInputQueue.SendKeyin "TEXTSTYLE ACTIVE  style_name"
             CadInputQueue.SendCommand "TEXTSTYLESET ColorValue ""7"" ""style_name"""
             CadInputQueue.SendCommand "TEXTSTYLESET Height " & Str(0.22 * fsx) & "style_name"""
             CadInputQueue.SendCommand "TEXTSTYLESET Width " & Str(0.187 * fsx) & "style_name"""
             CadInputQueue.SendCommand "TEXTSTYLESET SingleLineJust CENTERCENTER ""style_name"""
    Massimo Callegher
    Answer Verified By: SteveMeyer
Reply
    Massimo Callegher
