Locate a Gap in an Area...
Hello there,
I have some roads that i need to measure their areas for bill of quantities purpose, so I'm using the measure area tool using the method of flood then i select the elements that i need to measure their area, then this message appears "Error - No enclosing region found". The Max Gap is set 0.01
But when the Max Gap is set to 0.1 it reads the area.
So, my question is, is there any way that i can locate this Gap instead of spending time to find it???
Thanks & Regards
Parents Reply Children
