MicroStation performance slow when opening certain files
(Posted on behalf of Be Communities member)
Using MicroStation V8i Select Series 2  08.11.07.443 running on Windows 7 64-bit machine with 16 GB or memory.
Experiencing slowness when opening certain DGN files on the network. The dgn files average size is around 5 MB and there are reference files attached from network. User experience slowness with cursor movement and when clicking on certain menu items.
What are some things that can be check to see what may be causing the problem?
