Levels levels levels
I have a converted dwg  to dgn file utilizing model and sheet. I can't believe the amount of locations that it's possible to change a reference level's display properties, not to mention the fact the process is multiplied by 2 for on/off state changes. I'm completely overwhelmed.
I realize the initial creator of the file is mostly to blame but could someone help me get a handle on this? I'd like to control all the levels in one location. Additionally, I can't seem to find a setting to hold the level settings so they all revert after open/close. (dwg visretain=1 already??)
    Is your question related to the default Microstation Level display  mechanism or DWG related, only.
    Are you familar with the " default Microstation Level display  mechanism"?
    For DGN files your have three "Level display methods" (see the Level Display Tool)
    1. DISPLAY ON/OFF Level per View (not DWG compatiblel, but Microstation Default, for SAVE AS DWG see the DWG-Options)
    2. GLOBAL DISPLAY  ON/OFF Level (DWG compatible)
    3. GLOBAL FREEZE LEVEL ON/OFF (DWG compatible)
    and
    4. for Reference attachments there is a GLOBAL/ON OFF
    Indeed a Reference Attachment may have a level assingment in an DGN-Model like in AutocAD (DWG)
    You may not use "file/Save settings" to revert you level settings after reopening your dgn file. Better try to use
    "SAVED VIEWS" for different Level settings and reusing them.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • thanks for the detailed response. I'm familiar with the level display mechanism in your first screenshot. however it doesn't seem to be working the way I interpret it.
    My files and ref files are dgns but i'm unable to freeze a level globally (it only does it in model but the sheet ref level remain on) if I try and freeze a ref level in a sheet ref (viewport) I get a warning saying I can't do it there.
    ref level overrides are on.
    I'm not sure what you are saying in the last sentence but levels seem to be maintaining their settings after save/close now. (not sure what I did)
  • Spear- did you ever get this resolve?  I'm having trouble trying to keep certain levels on in my sheet after Save setting and closing it.  when i reopen file it the levels are off again.
  • Cause it's an F ing cluster mess. Try (temporarily) forgetting everything you know about level manipulation in Microstation. Then re-learn from AutoCad concepts. There is no such thing as a Viewport, Microstation sheets use reference files, not viewports. The entire Viewport concept is where we get tripped up, similar, but different. I always hate it when I have to work a project in DWG format, but it's rare.
  • found a solution that works for me:
    sheet view- level override ON
    ref file - Display Overrides: ALWAYS
    level Display - set levels on/off
