Dialogs do not appear
(Posted on behalf of Be Communities member)
Using MicroStation Select Series 3 on Windows 7 64-bit machine
When using tools such as place line or place fence tool settings dialog does not appear. When attempting to open dialogs such as reference file manager or the model dialog these will not appear as well. Clicking on Windows>Place Line (tool settings) pull-down menu does not bring up the tool settings. Also verified that the Setting>Tool Setting pull-down menu option has a check beside it.
When MicroStation is open and is in the foreground when clicking on other open applications in the task menu they never appear in front of MicroStation but appear behind in the background. Could the same be happing with the MicroStation dialogs?
