I would like to change the projection of this file and also reproject all the elements.
The file is currently in NTF Lambert -1. When I try to change the projection in "RGF93.CC49 - RGF 93 Lambert Zone 8" with the option "reproject datas..", I have an error message:
This file is included in the post.
Thanks for your help
Hervé Cuzon
You should contact the Bentley Select Support :
appsnet.bentley.com/.../addcall.aspx
Frank
Bonjour Mr Cuzon
element id:4635
HTH
LaurentD
Ok but what is the problem with this element?
Hervé
Can you please let me know hat version of MicroStation are you using?
There seem to be quite a few errors in the file and they get carried over to a new DGN.
Try the following:
1. Create a new dgn and set the required GCS
2. Reference "ensemble LZ1.dgn", choose the geographic positioning option and the merge the reference into master.
3. Try changing the coordinate system
On my machine it does not crash anymore but there are some errors during the GCS conversion reported in message centre.
My MicroStation version is : 08.11.09.459 (French)
I've tried your procedure but it still crashes.
Is there a log file I can send you to?
Can you tell me what kind of elements are corrupted?
