(Posted on behalf of the user)
I'm trying to override the element symbology of an attached reference file using the level manager and it is giving me this message:
"reference level overrides is off. level change is valid only in current session. the change has not been written to file."
Where is this setting and how can i change it? it's only happening in certain files. Other files, I can change the symbology of reference files using the level manager override and it saves it.
if the reference is refered into the model space then the model space is refed into the sheet then in the sheet it is indeed treated as a Nested ref.. but if the model space is not using a ref then in the sheet it is not nested...
Steve Cross said:It must be a setting in the file the drawing is referenced to as I can't save any Reference File level overrides in this file. I get the same message with every reference file I attach. I have attached the reference file to other drawings and I am able to save the overrides. This may have been an old SEED file from the dark ages that got copied over with this old project.
If it is not a ref file in the model space then changing the overrides in the model space view should change the way the sheet looks.. but from your reply you use the phrase referenced to so we are unclear as to what your work flow is..
look at the ref manager bottom rows and set overrides to always while your in the sheet view model...
Try detach and reattach the ref into the sheet ... this usually fixes the problem...
Lorys
