Insert Text Field tool, I wish to turn off the Label (mm) when I select the length of a line element.
But I can't see the column that allows you to turn off the unit labelling for Lines?
It is there when I use an Area of an element. But not for lines??
Is this supposed to be the way it is? Known bug?
AECOsim BD 8.11.9.376.
Under the ' Linear Unit Format heading ' try changing the ' Label Format ' from ' Use Active Settings ' to say ' MU ' ( Master Units )
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: Damon Aspden
Ah. I see. It has 2 types of definition. 'MU', and 'MU Label'.
So if I choose 'MU' it only shows the numerical length, if I choose 'MU Label', it shows the unit label also.
Nice catch. ty.
PS. Nice consistency Bentley??? not.
