I have a problem now where I can't drag to select objects above a raster image. Previously the raster was only selectable via a crossing mode selection across one of its edges. Now if I click and drag to select a group of elements, in front of or behind the raster attachment, Microstation is interpreting that as a command to grab and move the raster.
What did I toggle for it to behave like this now?
Instead of this:
I'm getting this:
Try turning on "Ignore Locate Interiors" in the Workspace > Preferences > Raster Manaager.
Answer Verified By: Adonis
I also find it beneficial to use Edit>Lock to lock the raster file in place one you have it where you want it and prevent unintended moves.
Thanks a million Karl!
Another good option to toggle On is the "Disable delete Element Tool on Selected Rasters" Prevents detaching the Raster by accident!
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
