I need help because I am new user of this design software.Please,i need todo know: How I can eliminate some layers of a file?. I try todo eliminate layers with Menú - Settings - Level - Manage But,I can't eliminate its.Please I'll wait yours request.
Try using the key-in:
level element delete <level name>
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Try following the steps in the wiki "Deleting Levels":
communities.bentley.com/.../deleting-levels.aspx
HTH,
Tamicca
Tamicca SellarsProduct Manager I
It's a long lonely road - until just recently - but now
communities.bentley.com/.../91697.aspx
communities.bentley.com/.../91696.aspx
communities.bentley.com/.../91572.aspx
and more to come
First make sure the levels are in your file or coming from a dgnlib file. This is just a drawings with a different extension. Just a drawing. And levels should be kept here not in a file unless they are stickly for that particular file.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
You cant really delete a LEVEL ( not layers thats autocad) if there is data on it you need to move data to a level you want to keep or rename elements level that are on now to another existing level then you can delete the empty level via the LEVEL MANAGER not the LEVEL DISPLAY manager
you need to buy a book or 2 on microstation aimed at new users .. I can recommend keith Little's survivors guide to v8 ( ebook $7usd ) and the xm update ( ebook $1usd) get these from www.adagebooks.com
(email me if you cant find them...)
you'll learn very quickly all the basics that are still the same in V8i and its the basics thats holding you up
Levels, level librarys, accudraw , reference manager and tools, customisation of F keys, scripts and keyins
cells ( blocks to acaders) printing these are the basics once you quickly master these you'll understand the help file and will be doing the advanced stuff like macro recorder for VBA...
Lorys
