See attached picture of the key in command and structure. It will not toggle the grid? I need some Ideas on the problem, when and if possible.
When it is on, it will not toggle OFF.or when ON, it will not toggle off.
Hi Richard,
I assume (you didn't write it) you want to switch on/off grid display in VIew Attributes, not grid switch in MicroStation Locks settings. In such case this key-in is the right one ... you just to have check what MicroStation tells you and requires from you.
If you use set grid toggle key-in, MicroStation asks you to identify a view. It means this key-in has always to be followed by datapoint (user interaction) or selview <view number> key-in. So the full key-in has to be something like set grid toggle;selview 1.
BTW You discussed the same topic two years ago in this thread.
With regards,
Jan
Hear is the strange case.
set ed toggle;selview all;update all, This works fine as a direct Key-in. But a Script File will not seem to work
@C:\scripts\dft.txt
I first tried
set ed toggle
selview all
update all
it would not work either. The datafields blink on and off on the screen? normally the toggle command will flip off to on or on to off.
I have another script file GDT.txt in the same folder which works.
gdt.txt which works fine
set grid toggle
selview ALL
update All
This one works fine locksOn.txt
lock grid on
lock axis on
lock unit on
lock snap keypoint
Here are a couple of pictures of the three separate C:\Scripts\ (file_name.txt)
The above did not work in either format, the Direct F9 did
Below worked fine as a script file
I am pasting a copy of the path in text format: C:\Scripts I hope I have given enough information? Thanks you for any assistance.
RJB Phillips III - Praise the Lord for His Mercy and Grace
Sometime, in a script, using a precision input key-in works where others do not.
You can enter xy=0,0 or dx=0,0 and I believe you can add an extra comma and a view number - but this requires your script to know whether its running in 3D or 2D. When using a zero, you can actually omit the comma.
DX=,, is the same as DX=0,0,0.
Richard
Have you tried using the macro recorder and doing your kein ins on at a time. then turn off or stop recording
you can name your macro something more logical or GDT then if you saved them in the right default folder you can run them by keyin macro macroname enter key ie macro gdt or just macro and a dialog pops up and you browse to the one you want... pretty cool and easy to remember... also can contain explanation as the file has an editor or you can use notepad as long as it the . bas file you can edit it...also run and step thru it to see where its wrong or fails....
or use the F keys to launch the macro.... macros are easier then scripts because it records what your doing and if it works you keep recording... a lot of people will push for VBA macros here but if your not up to vba then for now microstation basic is pretty easy to read and and understand what happening... and as your a good old boy like me basic should come easy to you...
Lorys
I must have misunderstood the above answer BeMVP, I opened the key-in and typed in xy=0,0 do not think saw any change in the datafields? I then tried dx=0,0 I only am in 2D drawing and do not think I will be going into the 3D I am just a part timer doing 2D updates and corrections.
we are talking of the vba macro recorder? or is there another recorder and I am not aware of it?
If I put this into the key-in browser:
set ed toggle;xy=
My message center reports:
Enter data on : 1,2,3,4,5,6,7,8
or
Enter data on : 2,3,4,5,6,7,8
after each entry which confirms its accepting my entry.
To toggle grids use:
set grid toggle;xy=
If you need to force an update, add UPD ALL issues an update view
Also, sometimes the tool settings gets out of synch. Adding a UPDATE VIEW;RESET starts the update view command which sets the tool lettings for itself and the reset cancels the view command causing the tool settings to revert back to the original command.
BTW, BeMVP is not my signature, it is a banner from the newsgroup, recognizing certain individuals for their contributions here.
CADDCOP
A MicroStation user since IGDS
