In the lower left corner of my screen there was a readout you could enter distance into when drawing a line I cannot make a picture I lost the display? what did I get turned off by mistake? there were two readouts in this lower corner, how do I get back on, I tried a Co-ordinate search, but did not find my answer.
Would any of this be in my problem? maybe something set wrong, I see the view center on active Z, but I am only doing 2D never the 3D.
RJB Phillips III - Praise the Lord for His Mercy and Grace
Ok, I just found it under the coordinates tab, Thanks to the above answer on it was Accudraw, It put me on the right trail and allowed me to find the answer.
It was on polar? perhaps it was just this drawing that was setup wrong. should the Unit round be checked? or will that lock up something else? Anyway I got the X Y back, but I do use the Q for lines and it does seem to turn it off and on??
someone mentioned taking the Q out of something, but not sure what was meant or how to do it. Thanks to all who tried to assist me in fixing another mess I must have made.
When Accudraw has focus, hitting the space bar toggles the mode between rectangular and polar. You (or another user) may have accidentally changed it.
Answer Verified By: RJB
Thank you John, that makes sense, I knew I did not remember going into the check boxes and changing any. I appreciate your taking the time to respond.
